kabirsaini
To begin the manual conversion of an OST file to PST, you must first log in to Outlook using the Exchange account that was originally used to create the OST file. Once you're logged in, follow these simple steps to export the OST mailbox to a PST file:
If you're unable to access the Exchange account or want a faster and more flexible solution, consider using the GoldyTools OST to PST Converter. It offers a user-friendly interface and advanced features that simplify the entire process—no Outlook or Exchange profile required.
- Go to File > Open & Export, then click on Import/Export.
- Select Export to a file and click Next.
- Choose Outlook Data File (.pst) and click Next again.
- Select the folder(s) you wish to export, then click Next.
- Click Browse to choose the destination for the new PST file, and select your preferred option for handling duplicate items.
- (Optional) You can set a password for the PST file, or simply skip this step to continue.
Note: This method works only when you have access to the original Exchange profile.
