whats wrong
cmack
i have windows vista home, and i just upgraded your package and it crashes whenever i try to add a task.
You probably have a problem with the Task List. In the FAQ topic entitled 'Common Eraser problems' you will find details of how to delete the Task List. Do this, and re-start Eraser. If that doesn't work, please give details of any error messages you are getting, and we'll try other things.
If that doesn't work, can you list the drives installed on your computer (including TrueCrypt ones/virtual ones)
