carljames
If your main priorities are simple and accurate, then I would suggest you try the MailsDaddy Gmail Backup Tool. This is one of the best options because its simple and clean user interface, easy to understand, and requires no technical skills. Users just log in, choose the output format, and export their data. It’s ideal for home users, professionals, and businesses looking for a dependable Gmail backup utility.
