Ramveersingh
There are several scenarios where you might need to convert an OST file to a PST file, such as when the OST file becomes inaccessible due to a sudden power outage, an Exchange server crash, or if the OST file is orphaned due to changes in the Outlook profile. Users may also want to open another OST file in the same Outlook, which requires conversion to PST.
Unfortunately, there is no direct way to use an OST file in any version of MS Outlook. To resolve this, you’ll need reliable third-party software to convert the OST file to PST. I highly recommend downloading and installing Goldytools’ OST to PST Converter, one of the best tools for this task.
With Goldytools, you can easily convert your OST files to PST and access your valuable data with ease.
Key Features of Goldytools OST to PST Converter:
- Quickly Convert OST to PST – Fast and efficient conversion.
- Supports Conversion to EML and MSG – Offers flexibility for other formats.
- Compatibility with All Outlook Versions – Works with both 32-bit and 64-bit versions of Outlook.
- Full Windows OS Support – Fully compatible with all Windows operating systems.
