Why is OST to PST conversion a common practice in 2025 for Outlook users?
Aaravthakur
Reliable OST to PST Conversion with GoldyTools​
There are several scenarios where converting an OST file to a PST file becomes necessary — for example, when:
  • The OST file becomes inaccessible due to a sudden power outage
  • The Exchange Server crashes
  • An Outlook profile is modified, resulting in an orphaned OST file
  • A user wants to access an OST file on a different Outlook profile or system
Unfortunately, Microsoft Outlook does not provide a built-in solution to open or import OST files directly. To resolve this, you’ll need a trusted third-party solution.
We recommend GoldyTools OST to PST Converter, a reliable and efficient tool designed to convert OST files into PST format quickly and securely.
Key Features of GoldyTools OST to PST Converter:​
  1. Fast & Accurate Conversion – Instantly converts OST files to PST without data loss
  2. Multiple Export Options – Also supports conversion to EML and MSG formats
  3. Wide Compatibility – Supports all Microsoft Outlook versions (32-bit & 64-bit)
  4. Fully Windows-Compatible – Runs smoothly on all Windows operating systems
Additionally, the free demo version allows you to preview the first 25 items from each mailbox folder before purchasing.
