winimage
Does anyone know how to use winimage as the install.bat does not work with xp with dban. The file that is downloaded for a floppy is compressed so does the file have to be opened and copied with winimage and transfered to a floppy and if so will the computer reboot with the info in the file or does the floppy have to first be formatted as a boot floppy? Or do you just copy the entire compressed file to floppy...
thanks
terry
perda04
Winimage instructions
As the instructions that accompany winimage may not be clear enough:
File
open ( select the file dban_1_0_2_i386.img )
Disk
write disk
