Hi
When I delete files over a certain size, XP notifies me that they are too large to fit in the Recycle bin and will be deleted. I understand that they are not really deleted but the space they occupied is made available for re-use.
If I accidentally deleted a file in this way that I really wanted to erase, would the only solution be to wipe the free space on the partition the file was on? I'm thinking it might be quicker to undelete the file and then erase it. Is there a free/cheap utility that could do this quite easily?
On the subject of the Recycle bin, is there any difference in security terms between erasing a file and erasing the recycle bin after the file has been put in it?
