Hi,
Ive been using Eraser for a while now. This morning I got up and Eraser appeared be taking much longer than normal (several hours...normally its an hour operation max). I hit the stop button, Eraser crashed along with XP. I rebooted. Reboot failed due with an error message "NTLDR is missing Press Ctl+Alt+Del to restart". I cannot boot XP or get into my C drive to try to delete the eraser temp file. I suspect that this file has completely filled up and/or fragmented my HD and is causing the problem. Any ideas on how to fix this? I cant seem to access the C drive at all using the boot CD.
Thanks,
Spimby
Thanks,
Spimby
