XP Explorer problem
Zoar
I had an older version of eraser installed on XP and integrated into explorer (gave options of “Erase” and “Erase secure Move” etc) when you right click a file for deletion. I uninstalled it and installed version 6.0.6.1376 which works fine, except I now have both versions in Explorer which is annoying, obviously the uninstall didn’t remove this feature. Any idea how I can remove the old eraser options from explorer :o
Cheers, Zoar
Root: HKCR; SubKey: *\shellex\ContextMenuHandlers\Erasext; ValueType: string; ValueData: {{8BE13461-936F-11D1-A87D-444553540000}
Root: HKCR; SubKey: CLSID\{{8BE13461-936F-11D1-A87D-444553540000}; ValueType: string; ValueName: ; ValueData: Eraser Shell Extension
Root: HKCR; SubKey: CLSID\{{8BE13461-936F-11D1-A87D-444553540000}\InProcServer32; ValueType: string; ValueData: """{win}\System32\erasext.dll"""
Root: HKCR; SubKey: CLSID\{{8BE13461-936F-11D1-A87D-444553540000}\InProcServer32; ValueType: string; ValueName: ThreadingModel; ValueData: Apartment
Root: HKCR; SubKey: CLSID\{{8BE13461-936F-11D1-A87D-444553540000}\ProgID; ValueType: string; ValueName: ; ValueData: ErasextMenu
Those are the values you'll need to remove. (ValueData is the value of the registry value)
