Zimbra Mail Converter
camilia
Are you looking for a reliable solution to import Zimbra to Outlook? Then, you can try a commercial solution like KDETools Zimbra Mail Converter. The tool has many advanced features such as:
  • Zimbra Converter allows the user to import Zimbra to Outlook PST and different types of file formats such as EML, EMLX, HTML, PDF, NSF, OLM, and etc.
  • The tool support email server like Office 365 and Exchange Server account.
  • The software shows a free preview option to cross-check the email with the attachment.
  • The application is also compatible with all the latest versions of Windows such as Windows 10, 8, 7, 2000, Vista and etc.
  • The tool has no file size limitation to import oversized Zimbra files to PST.
More Information: http://www.zimbra-converter.com/info/free-zimbra-converter-to-export-zimbra-to-pst.html
The conversion tool Zimbra to PST Converter can transfer all email data from one tool to another can be applied self-sufficiently of the Windows you are using since the device controls them all. Download this TGZ to PST Converter Software to Convert TGZ emails to Outlook PST Format. It is not an easy task for the users to change different Zimbra files into outlook 2019, 2016, 2013, 2007 & 2003 mailboxes in a proper manner.
johnsheno
I recommend that you use SYSessential TGZ to PST Converter application, which is an excellent solution for exporting TGZ mailboxes to PST files that support all Microsoft Outlook versions, including Outlook 2019, 2016, 2013, 2010, 2007, and 2003. This solution has a pre-survey feature that allows for a faster conversion of TGZ to PST without causing data corruption. It is tolerable for all Windows OS platforms such as Win 10, 8.1, 8, 7, XP, Vista, etc.
Jonasnick
If you need to a few simple answers for trading Zimbra documents to PST. I might want to propose Vartika Zimbra Converter Tool that gives simple and exact relocation of Zimbra messages, contacts, schedules, attaché, dissemination records, repeating schedules and so on to PST design. When you have Zimbra records in PST design, you access them in Outlook 2019, 2016, 2013, 2010, 2007 and 2003 versions, with careful subtleties.
Know more info-
https://www.vartikasoftware.com/product/zimbra-to-pst-converter.html
If you are trying to convert Zimbra to Outlook PST, I would like to suggest the TGZ Exporter tool that provides easy and accurate migration of Zimbra Emails, attachments, contacts, calendars, notes, etc. to PST format. you can easily export all the Zimbra TGZ data into multiple formats like PST, EML, EMLX, MSG, and MBOX formats without any data loss. It also works on all MS Outlook versions like 2019, 2016, 2013, 2010, 2007, 2003, etc.
Visit here for more info: https://www.betavare.com/tgz/
facoc57
Use Zimbra to Outlook Converter Tool that will definitely help you export Zimbra to Outlook PST file. It smoothly manages all the contents of the mailbox which includes emails, calendars, notes, briefcase, contacts and etc. Easy and Understandable GUI which can be utilized efficiently by non-technical to implement the migration process. Zimbra to Outlook Converter for Windows which makes the process more easy and simple for a user to implement. This software supports all Windows OS & MS Outlook versions. You can download its trial version first, the trial version converts a few items from each folder.
