If your Zimbra to PST migration is taking too long, you can speed up the process by using a tool like FixVare TGZ to PST Converter. This software makes the migration faster and easier, handling large TGZ files without any issues while ensuring that all your data, including emails, contacts, and calendars, are accurately converted to PST format without any loss. Plus, TGZ to PST Converter is easy to use, supports batch conversion, and ensures that your folder structure and other data are retained. It runs with all Windows versions. The software is user-friendly, making it accessible for even those with little technical knowledge, and it offers a free trial version so you can test it out before making a purchase.
