Add task error: E_ACCESSDENIED
Hollows
Task Properties Error - I am unable to Add Data to the task.
Text of Message "Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit the application will close immediately.
Access is denied. (Exception from HRRESULT: Ox80070005 (E_ACCESSDENIED)).
Program closes if either option is chosen. I have tried running the application both as Administrator and as Normal User, same result in both cases.
I have no option in Add Data dialog box to disable Erase Cluster tips.
Additional information contained in box is as follows:
"See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.UnauthorizedAccessException: Access is denied. (Exception from HRESULT: 0x80070005 (E_ACCESSDENIED))
at Eraser.Util.VolumeInfo..ctor(String volumeId)
at Eraser.Util.VolumeInfo.get_Volumes()
at Eraser.TaskDataSelectionForm..ctor()
at Eraser.TaskPropertiesForm.dataAdd_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Eraser
Assembly Version: 6.0.6.1494
Win32 Version: 6.0.6.1494
CodeBase: file:///C:/Program%20Files/Eraser/Eraser.exe
Eraser.Manager
CodeBase: file:///C:/Program%20Files/Eraser/Eraser.Manager.DLL
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
Eraser.Util
CodeBase: file:///C:/Program%20Files/Eraser/Eraser.Util.DLL
Eraser.DefaultPlugins
CodeBase: file:///C:/Program%20Files/Eraser/Plugins/Eraser.DefaultPlugins.dll
System.Core
Assembly Version: 3.5.0.0
Win32 Version: 3.5.30729.4926 built by: NetFXw7
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
Eraser.resources
CodeBase: file:///C:/Program%20Files/Eraser/en/Eraser.resources.DLL
BevelLine
Assembly Version: 1.0.3589.29437
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/Eraser/BevelLine.DLL
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Eraser.DefaultPlugins.resources
CodeBase: file:///C:/Program%20Files/Eraser/Plugins/en/Eraser.DefaultPlugins.resources.dll
Eraser.Manager.resources
CodeBase: file:///C:/Program%20Files/Eraser/en/Eraser.Manager.resources.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box. "
Thanks
Re: Windows 7 Report Errors
Once again, I need the complete partition information of every disk and partition in your computer (mount points, file system, TrueCrypt/BitLocker, interface (SATA/IDE/SCSI)) including EISA partitions and removable drives. This bug seems very evasive...
Hollows
I am sorry I am a relative newcomer to computing. Can you please advise how I can obtain the informatio you have asked for.
I have a single partition on my Laptop (Drive C:) Operating system Window 7 Home Premium the Hardrive is a SATA drive. Removable drives are a DVD Rewritable (D:) and also I use a USB Pen (E:). I do not use TrueCript or Bit Locker.
I have attached a copy of a HTML Report of the system file I have created, I hope this is of help, please let me know if you need anything further.
General
Windows Microsoft Windows 7 Home Premium Edition (build 7600), 32-bit
Windows Directory C:\Windows
System Directory C:\Windows\system32
Temporary Directory C:\Users\John\AppData\Local\Temp\
License
Registered Owner John
Registered Organization
Product ID 00359-112-1132581-85456
Identification
Computer JOHN-PC
User John
System Folders
Current User
!Do not use this registry key Use the SHGetFolderPath or SHGetKnownFolderPath function instead
Administrative Tools C:\Users\John\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
AppData C:\Users\John\AppData\Roaming
CD Burning C:\Users\John\AppData\Local\Microsoft\Windows\Burn\Burn
Cache C:\Users\John\AppData\Local\Microsoft\Windows\Temporary Internet Files
Cookies C:\Users\John\AppData\Roaming\Microsoft\Windows\Cookies
Desktop C:\Users\John\Desktop
Favorites C:\Users\John\Favorites
Fonts C:\Windows\Fonts
History C:\Users\John\AppData\Local\Microsoft\Windows\History
Local AppData C:\Users\John\AppData\Local
My Music C:\Users\John\Music
My Pictures C:\Users\John\Pictures
My Video C:\Users\John\Videos
NetHood C:\Users\John\AppData\Roaming\Microsoft\Windows\Network Shortcuts
Personal C:\Users\John\Documents
PrintHood C:\Users\John\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
Programs C:\Users\John\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
Recent C:\Users\John\AppData\Roaming\Microsoft\Windows\Recent
SendTo C:\Users\John\AppData\Roaming\Microsoft\Windows\SendTo
Start Menu C:\Users\John\AppData\Roaming\Microsoft\Windows\Start Menu
Startup C:\Users\John\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
Templates C:\Users\John\AppData\Roaming\Microsoft\Windows\Templates
{1B3EA5DC-B587-4786-B4EF-BD1DC332AEAE} C:\Users\John\AppData\Roaming\Microsoft\Windows\Libraries
{374DE290-123F-4565-9164-39C4925E467B} C:\Users\John\Downloads
{4C5C32FF-BB9D-43B0-B5B4-2D72E54EAAA4} C:\Users\John\Saved Games
{56784854-C6CB-462B-8169-88E350ACB882} C:\Users\John\Contacts
{7D1D3A04-DEBB-4115-95CF-2F29DA2920DA} C:\Users\John\Searches
{A520A1A4-1780-4FF6-BD18-167343C5AF16} C:\Users\John\AppData\LocalLow
{BFB9D5E0-C6A9-404C-B2B2-AE6DB6AF4968} C:\Users\John\Links
Common Folders
Common Administrative Tools C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
Common AppData C:\ProgramData
Common Desktop C:\Users\Public\Desktop
Common Documents C:\Users\Public\Documents
Common Programs C:\ProgramData\Microsoft\Windows\Start Menu\Programs
Common Start Menu C:\ProgramData\Microsoft\Windows\Start Menu
Common Startup C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
Common Templates C:\ProgramData\Microsoft\Windows\Templates
CommonMusic C:\Users\Public\Music
CommonPictures C:\Users\Public\Pictures
CommonVideo C:\Users\Public\Videos
Environment Variables
ALLUSERSPROFILE C:\ProgramData
APPDATA C:\Users\John\AppData\Roaming
COMPUTERNAME JOHN-PC
ComSpec C:\Windows\system32\cmd.exe
CommonProgramFiles C:\Program Files\Common Files
FP_NO_HOST_CHECK NO
HOMEDRIVE C:
HOMEPATH \Users\John
LOCALAPPDATA C:\Users\John\AppData\Local
LOGONSERVER \\JOHN-PC
NUMBER_OF_PROCESSORS 2
OS Windows_NT
PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PROCESSOR_ARCHITECTURE x86
PROCESSOR_IDENTIFIER x86 Family 6 Model 14 Stepping 12, GenuineIntel
PROCESSOR_LEVEL 6
PROCESSOR_REVISION 0e0c
PSModulePath C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
PUBLIC C:\Users\Public
Path C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Common Files\Microsoft Shared\Windows Live
ProgramData C:\ProgramData
SystemDrive C:
SystemRoot C:\Windows
TEMP C:\Users\John\AppData\Local\Temp
TMP C:\Users\John\AppData\Local\Temp
USERDOMAIN John-PC
USERNAME John
USERPROFILE C:\Users\John
windir C:\Windows
System
Processor Architecture INTEL
Granularity Of Page Protection And Commitment 4 KB
Lowest Memory Address Accessible To DLLs 00010000
Highest Memory Address Accessible To DLLs 7FFEFFFF
Active Processor 11
Number Of Processors 2
Processor Type INTEL PENTIUM
Granularity Virtual Memory Allocated 64 KB
Processor Level INTEL 6
Processor Revision 00000E0C
Shared Resource
Remote Admin C:\Windows
Default share C:\
EPSON Stylus SX200 Series EPSON Stylus SX200 Series,LocalsplOnly
Remote IPC
Printer Drivers C:\Windows\system32\spool\drivers
Default share Q:\
Users C:\Users
John
