Asus A7n8x MB Nforce
fusion1296
hi all , i have used Dban for a while now and all has gone well, a few weeks ago i changed my motherboard to the above now when i run the program it works ok for a while then it freezes, the harddrive light stays on but the program percentages and everything else just stops , does anyone else have this MB and can you tell me if it works or doesnt ??? i want to get it to work but if it doesnt on this MB i dont want to waste time getting it going if it doesnt work , i have tried loads of differnt configurations , master , slave primary secondary etc , i have forced to to ATA 33 with a cable ( usually it ATA 100) i have tried 3 differnt drives all fail between 30 - 40 % if i out them in old PC all is ok , if someone has it going can you teel me what Bios version you are using .
thanks in advance for help .
