auto dban on boot
Dade22
Im looking for a way to automate the process of DBAN. I would like to set up a boot disk that will nuke all detected drives on boot without any user interaction.
I need to set it up so that it wipes on boot with the 2nd to highest security setting.
Anyone have a way to do this with DBAN???
marcus
dajhorn said:
Edit the A:\SYSLINUX.CFG file.
this is what he ment:
right click the .cfg file and open with notepad.
It will look like this:
Code:
# syslinux.cfg: Boot loader configuration file for Darik's Boot and Nuke.
#  WARNING: Only use notepad to edit this file.
#    This file is line and case sensitive. Ensure that your text editor does not
#    automatically insert line breaks or otherwise apply automatic formatting.
# Set this option to zero if you wish to skip the boot prompt.
PROMPT 0
# This label will be started if you just push enter at the boot prompt, or if
# you set the PROMPT option above to zero.
DEFAULT dod
I set my Prompt to 0 and mt default to dod
