Best Email Converter
anonymous
Email Converter software is a multi-converter utility programmed to support conversion of different types of email files into other popular file formats. The input file formats supported by this tool are: DBX, PST, EML and MSG. Email Converter is a small program that you can use to convert email message files (.eml) to .msg, Text or HTML format.It is very efficient tool to import Outlook to Outlook Express and Outlook Express to Outlook.
Features :-
  • Conversion of PST file to EML, DBX, HTML, RTF and MSG
  • Conversion of DBX file to EML, PST, HTML, RTF and MSG
  • Conversion of EML file to PST, DBX, HTML, RTF and MSG
  • Conversion of MSG file to EML, PST, DBX, HTML and RTF'
Get more detail :-
devin
I would like to suggest MBOX to Outlook converter. It is specially performed for more than 30 MBOX based email client to Outlook migration such as Apple Mail to Outlook, Thunderbird to Outlook, Netscape to Outlook, Entourage to Outlook, SeaMonkey to Outlook etc. The software also keeps same folder structure, Message Body, meta data & attachments after converting MBOX to PST.
Visit at ; Tool to Convert MBOX to PST to View Mailbox Data in Outlook 2016 & Other Versions
There are so many email converters as there is a wide range of email clients available. So, one needs to search the converter tool as per their requirement.
samuelsarah
You can try the DBX Converter for migrating your files. It's an advanced tool that can easily migrate your unlimited files to various formats of DBX to EML, EMLX, MSG, MBOX and PST. It can provide you with 100% results. The DBX Converter tool allows users to open DBX files in MS Outlook, Apple Mail, Thunderbird, WLM, and other formats. It also provides a trial mode for every user for their satisfaction.
Visit here:- Convert DBX File with MailsClick DBX Converter to Export MS Outlook Express
jamesband
You can check out the Softaken MBOX to PST Converter software which will help you in transferring the data safely and instantly. This application can runs in all updated versions of Windows Operating System and make the migration process safely done. To know more this tool you can visit here:- https://www.softaken.com/mbox-to-pst-converter
