Best OST to PST Converter
camilia
I would like to suggest your best OST to PST Converter from Perfect Data Solutions is the ultimate way to convert OST File. This conversion tool is 100% helpful to convert all corrupted or damaged OST files into PST File format and also convert OST files in multiple file formats without any loss of data. The scanning process of this converter tool is very fast it quickly scans all OST files and converts them into PST File formats within a few minutes.
Some Features of OST to PST Converter:
• Converts unlimited size of OST file without any issue.
• Converts OST files into multiple formats like EML, MSG, HTML and PDF formats.
• It gives message filtering option to filter the message between “Start date” and “End date”.
Split large PST File into small PST File up to 5 GB.
• Easily Import OST files into Office 365 and Live Exchange Server
• It also supports all MS outlook versions 97, 2000, 2003, 2007, 2010, 2013, 2016 and 2019.
Download Free Demo version of the software visit:
ruchika
I would like to suggest IGnissta OST to PST Converter utility software. This OST Converter is best utility software to convert ost file to pst file.
  1. No File Size Limitations, Convert unlimited OST file to PST file
  2. Provide 100% Safe and Secure conversion results with 100% data accuracy
  3. Capable to convert OST file to Multiple File format like: OST to PST, OST to MBOX, OST to Vcard, OST to EML, OST to MSG
  4. You can also convert OST file to Office 365 with 100% data accuracy
  5. Split Function available to convert large OST file to small size of PST file
  6. Trail version is available to test software features with free of cost
Download Trail Version and convert ost to pst converter with 50 emails items per folder Best OST to PST | OST to PST Converter | Convert OST to PST File
1. Browse and Select OST file
2. Preview Email Items
3. Export to PST file
jackbryan
To get best recovery of damaged OST file use eSoftTools OST to PST Converter Tool, this tool offers the conversion of OST file into multiple formats like Office 365, MBOX, CSV, EML, MSG, vCard, HTML, PST Outlook. Before the conversion a smart preview is shown to the user to before the conversion, by this preview user can easily check and confirm the conversion format. This program does not require installation of MS Outlook for the conversion of OST file. A FREE DEMO version is also available of this tool, you can easily convert 50 emails from each folder into each format.
samuelsarah
Easy and the best solution is available here MailsClick Convert OST file to PST application to convert the Outlook OST file data into another file format. download this free tool for converting file from OST to PST file format.
jamesband
You can use the OST to PST converter is a trustworthy software. You can migrate OST file to PST and multiple file formats. The OST to PST Converter imports all elements of the emails. You can use its free trial version to check the working of this tool. To know more visit here:- https://www.softaken.com/ost-to-pst-converter
Easy to use best OST to PST Converter SysOZ Software which has securely repair your damage Outlook OST file data as well as quick way to convert recovered OST file data into multiple file formats like as PST, MBOX, MSG, EML, vCal, EMLX and vCard file formats. This tool is nicely support all MS Outlook versions including Outlook 2019.
ruchika
I would like to suggest Ignissta OST File to PST Converter which convert ost to pst file with Ease and provide 100% safe and secure ost to pst conversion results. This software also convert large ost file we tested 210GB file which goves 100% safe, secure and fast conversion results.
Download and install from this link OST to PST Converter & Convert OST to PST File
Important Features for Ignissta OST Converter
  • No File Size Limitations, you can convert unlimited and large OST to PST
  • No Outlook Installation required while OST to PST Conversion
  • Provide 100% Fast, Safe and Secure conversion results with 100% data accuracy
  • Capable to convert all email properties like: To, CC, BCC, Attachments, Images, HTML format, Subject line etc
  • Support multiple file format like OST to PST, OST to Vcard, OST to MBOX, OST to EML, OST to MSG
  • Ignissta OST Converter also capable to convert OST to Office 365 as well
  • Split option to split large OST file to small size of PST file if Required
1. Browse and Select OST file ------------->
2. Preview Mail Items -----------------> 3. Export to PST File
Due to storage device failure, lost internet connectivity, sudden power failure, and malware attack if your OST file gets damaged so don’t panic and download ATS OST to PST Converter Software that is the best in data recovery filed. It not recovers the data but also converts into PST file format. It backing the version of MS Outlook from Outlook 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 up to 2019. Apart of PST, the user can store their data into several interesting file formats such as EML, MBOX, HTML, EMLX, MSG, vCal, vCard. Before the conversion, you can see the preview of recovered mailbox.
camilia
Easily search the best solution in the online market to Convert OST to PST file through KDETools OST to PST Converter software. It is the best option to export corrupt OST file data into new Outlook PST file with it also save multiple formats such as-: PST, Live Exchange, EML/EMLX, vCard/vCal, Zimbra, Gmail, Office 365, Drive, HTML, MSG and MBOX etc. This software 100% help you to transfer your important data from damage offline OST file to new formats PST along with it filter messages "First Date into Last Date "( Folders/size/Date)".
Read More-:
How to Export OST to PST
You can get back your OST file with the assistance of SysInspire OST to PST Recovery. It can work with all OST Outlook and also give a free addition, which gives 25 emails from every folder of Outlook OST file without cost and when you fulfilled with this software process then you can go for full version with just less cost.
You can pick eSoftTools OST to PST Converter software that is programmed with advance algorithms and best to achieve better results. With this tool you can straight-forwardly save OST data file to PST and many more formats like , vCARD, CSV, MSG, CSV, EML, EMLX, MBOX, Office 365 with single click. Positively application is capable to recover OST files, email properties, notes, schedule, attachments, contacts, etc and keep the originality of the data.
Get More Info About OST Recovery Software
The perfect software of all time named Mac OST To PST Converter, by this tool user can easily recover and transfer corrupted OST files data into PST Outlook without any difficulties and restriction. The Mac OST to PST Software is such an actual and safety application. you can use the free demo version of the software which converter 10 emails in each folder. The software supports all Mac OS Outlook versions like 10.10, 10.11, 10.12, 10.13, 10.14.
For more information:- https://www.toolscrunch.com/mac-ost-to-pst-converter.html
jackbryan
If you are finding the best OST to PST Converter Software but unable to the perfect answer, then I will recommend you to get the advantage the SysInspire OST to PST Converter Software. It will offers you some amazing features to make a smooth and safe conversion of OST file.
In my opinion, it is the best OST to PST Converter Software because it comes with an easy and reliable graphical interface by which any type of user can access this software flawlessly.
This utility is the most powerful application for converting OST file and it offers some amazing file options to convert OST like- PST, EML, EMLX, MSG, vCard, CSV, MBOX, HTML.
Through this program you can directly export OST items to Office 365 Cloud storage to manage some space from your system.
For More Info, Visit Here:- https://www.sysinspire.com/ost-to-pst-converter/
