Bootup Problem
verne
When I start up the computer I get the follow message:
"Unknown action: - hide
Press enter to continue . . .
Any ideas how to fix is?
Thanks in advance,
Verne
Sorry if this is a stupid question, but how do you know this relates to Eraser? If it does, what versions of Eraser and Windows are you using?
verne
Sorry about leaving this part out.
The top of the window that opens says:
C:\Program Files\Eraser\Eraser.exe
The version is 6.0.6 and the operating system is Vista.
Thanks,
Verne
Uninstall 6.0.6, and download and install 6.0.7.1893 (which erroneously describes itself as 6.0.6 on the Task pane header, but which has the correct details in its 'About' box). If you are already using build 1893, uninstall and reinstall it, to see if that helps.
You need to uninstall v5 as well to fix the problem.
