Can't Uninstall Eraser
Nemo
I've been using Eraser 5.8.8 for quite sometime now and decided to upgrade to the latest version.
For the life of me I can't get it to uninstall. It always says it's running and I need to close it. I can end the process but it still says it's running and won't allow me to uninstall it.
Any ideas as to how I can remove this version from my computer?
Thank you.
Nemo
Nevermind. All I needed to do was re-boot. *sigh*
Sorry.
Vanesse
You'd better close all running programs before you start uninstalling Eraser. You can also try uninstall it under Safe Mode or just use a cleaner tool to ensure a full uninstall.
