Clarification
Is there any way to clarrify that the drive has been wiped? Does the log file show if theres been any errors?
By default, DBAN will verify that the disk is empty after a wipe. To further clarify the result, you can set the verfication mode to "all passes" by pushing <V> at the selection menu.
For each device that was wiped, the log file indicates whether the wipe succeeded or failed. The dban-1.0.4 release more clearly indicates this than previous releases.
