If you are searching the NSF to PST converter and want the easy conversion. Must try the best incredible tool, Bitdataconversion NSF to PST Converter Tool. The tool provides the best features, it migrates the multiple Lotus Notes NSF files to PST, and save NSF files to EML, MSG formats. It provides a guarantee to convert NSF to PST(email, messages, contacts, calendars, journals). The tool supports all versions of Lotus Notes, Outlook, and Windows OS. if you want to check the functionality of the tool, you can download the free trial version of this tool and check all the functionality. With the help of this trial version, you can migrate the first 50 items per folder.
