crc error
I have tried all day to create a cd but keep getting a cd error once i try to run the program after bootup.
I have tried re-downloading the iso file from different locations and i have tried using different cd burning programs - all to no avail and it is driving me mad! I have created a cd successfully before but I have lost it so i am trying to create another. Please help! Thanks
The likely problem is that you are burning the blank CDR media faster than it is rated. Another possibility is that your burner has reached the end of its life. (The laser might be fading.)
Use another computer to burn the ISO.
thanks
Excellent! Thanks very much - that did the trick. I can't believe it was something so simple after spending all day trying to get it working! Thanks again.
