created a constant program exception
Mike_9
I somehow created a constant exception in Eraser while trying to erase an external HD. When I can get the dialogue open I see a couple of tasks that I can't change or clear. At least one is trying to run. Then it crashes with the following exception.
System.IO.FileNotFoundException was unhandled
Message: An unhandled exception of type 'System.IO.FileNotFoundException' occurred in Eraser.Util.dll
Additional information: The system cannot find the file specified. (Exception from HRESULT: 0x80070002)
Most times I can't even open the program anymore. Is there a temp file holding reference to the tasks that I can delete that may restore to program to it's initial state? Reinstall didn't help. Was unable to run a repair either. Any help is appreciated. Thanks in advance.
Paul Whitaker
I had this same issue, and it fixed to rename this file: %localappdata%\Eraser 6\Task List.ersy
