Try CSV to vCard Converter software which is a third-party utility and allows its user to select the entire CSV file, including its Name, Title, Email, Phone Number, etc., and convert them to Vcard format. This also goes through all the latest versions of Windows 10/8 / XP / Vista.
There is no built-in program or CSV to VCF Converter Application is available in MS Excel to import contacts through because Excel file doesn’t get supported through all of these platforms. So, to transfer Excel contacts into other platforms, users require converting Contacts List from CSV and Excel to vCard .vcf file. This software will help you to convert emails from CSV to vCard file format. This software supports all Windows OS versions. You can download the free demo version for the application.
Use CSV to vCard Converter and make the Migration process of CSV files to vCard easy. The software allows a simplified interface due to which operating it becomes too easy even for non-technical users. All contacts with their properties are securely Imported from the CSV file to the VCF file format.
Still looking for a solution to convert CSV file to VCF easily. Aryson CSV to vCard Converter is the most advanced tool to convert the CSV file to vCard or VCF with its attachments. CSV to vCard Converter online allows users to convert the CSV files and choose the vCard versions. The software provides three different versions of vCard like vCard 2.1, 3.0, and 4.0.
Excel to vCard Converter is the comprehensive and full-featured utility to convert Excel Spreadsheet XLSX / XLS to vCard format. It allows users to convert different Excel files XLS, XLSM, XLSB, and XLSX to vCard. The software is competent enough to create a single file for all contacts and saves it as blank contact without any data loss.
The greatest online tool for converting CSV contacts to vCard (VCF) format is ToolsBaer Address Book Manager Tool. It gives you an amazing feature of a Date Range Filter that helps users pick the start and end times to send emails between them. With the help of this tool, you can convert CSV files to VCF file format. Apart from this, accepts different types of vCard files. The Address Book Manager Tool allows you to save the finished vCard file to three different versions, 2.1, 3.0, and 4.0.
