Discussion of Eraser in alt.comp.freeware
JVC
There is much discussion in the alt.comp.freeware newsgroup regarding problems with the latest versions of Eraser. Look for the thread I started with the subject "Eraser 6 requires dotnet 3.5 or higher." If you want to defend your program, it probably would be a good idea to participate in the discussion there since getting an account with this forum is too much of a PITA for most people.
I did and I found it. By the time I read to the end of the thread, the polarisation seemed too extreme than it is reasonable to either defend nor support a side. I pass. Each side is equally opinionated and finding common ground will be difficult at best, most likely impossible.
