Done with errors
rikilla0789
The task i try and run says done with errors. I check the log and it says the program needs administrative privileges. I have allowed the progrom to run with administrative rights. I even went to the actually program instead of just checking the shortcut and it too has administrative set on the properties page. Now i dont know what to do to give it the permission it needs.
rikilla0789
nevermind figured it out. didn't completely exit it from the try. all good now.
Yes, that is most often the problem. I still make the same mistake myself sometimes ...
