EdbMails- EDB to PST Converter tool.
Codie
EdbMails is a unique EDB to PST Exchange Server Recovery solution. It's an EDB to PST Conversion utility which facilitates granular / brick-level Exchange Server Recovery with EDB to PST Conversion. EDB to PST Converter repairs corrupt or damaged Exchange EDB files and restores the mailboxes into Outlook PST file. You can easily view Mailbox data from the PST files using MS Outlook application. It supports MS Exchange Server Recovery for 2003, 2007, 2010 and 2013 corrupt and unmounted database.
Recovers Calendar, Attachments, Drafts etc., from the damaged EDB files
EDB to PST Exchange server Recovery tool helps you to recover mails, images, attachments, drafts, calendar, journals, appointments, tasks, notes, etc. from the damaged EDB files. Its ease of use GUI enables you to preview recovered mail items.
visit: https://edbmails.com
Garge
InQuit Software is provide best Exchange Server Recovery Software. this Software is easily repair & recover corrupted or damaged Exchange EDB mailboxes data and convert EDB to Outlook PST and multiple file format like: MSG,EML,EMLX,MBOX,vCard and vCal.
many feature available InQuit Exchange Recovery :
  • Repair corrupted / damaged EDB file.
  • Easily recover emails Calendar, Attachments, Drafts etc, from EDB files
  • Software designed to simple GUI using simple ways
  • support latest all Exchange Server.
  • support ms-outlook 2016 to all lower version (32 & 64 Bit )
  • demo version saving 30 mail item in all mailboxes.
  • 30 days money back guaranty.
try to software and more information visit: https://sites.google.com/view/edb-to-pst/home
Roach
Try Softaken EDB to PST Converter free tool to convert Exchange server EDB files into Outlook PST file format
crickwilli
Repair corrupt or damaged EDB files download an effective tool EDB to PST recovery tool. This tool easy to resolve all types corruption issues such as emails, attachments, contacts, calendars, tasks, etc. from corrupt EDB files. It supports all versions of MS Exchange server and all updated Windows OS versions. Visit here - http://www.recoveryfix.com/exchange-server-recovery.html
copegroups
I know that lots of software companies presently available in online market but every company can’t be trustable that’s why I choose Enstella EDB to PST Converter Software which gives paramount features to helps for conversion two type of EDB File into PST like as :- corrupt and working. This application gives facility to use other format to extract EDB Data and also access selective and whole mailboxes from Exchange EDB into every format with emails properties/ attachment/ journal/ calendar/ embedded image/ contact/files/appointment and junk mails etc. With the use of this tool you take advantage of emails filtering option to convert particular selective EDB Emails according to 2 dates “from date” to “to date”. You can use demo versions to restore twenty five EDB Emails per folder into each format without of any cost.
Read More :- EDB to PST Converter
Neil Pattrique
Before purchasing any paid software for EDB to PST conversion, you should use the ExMerge.exe utility. It's a freeware tool provided by Microsoft that can extract email messages from EDB files and export them to new PST files of Outlook client. The ExMerge.exe utility works with corrupt EDB files as well.
kagasgeorge
NO matter how long you corrupted EDB is, no matter what is the reason behind its corruption but here you have the solution for every problem for EDB to PST Recovery.
Get Exchange EDB Recovery Software here to recover Exchange EDB/recover EDB databases completely. It just restore data from EDB quickly. It can convert EDB to PST within limited time and all Exchange version up to 2016 and MS Outlook 2016. It provides multiple transformation as EDB to PST/EDB to MSG/EDB to HTML/EDB to EML.
Type in GOOGLE:
Exchange EDB Recovery Software -----------to get exact result for EDB to PST Conversion.
Codie
Here, We share another effective OST to PST converter to fix the error of OST files and access them quickly. OST to PST converter software performs flawless OST file recovery and OST to PST conversion. This tool is capable of saving recovered files in PST, EML, HTML, and MSG formats.
This application is for OST to PST converter
EDB to PST converter Software do not change the internal folder structure of Exchange Mailbox during the conversion of EDB to PST file. EDB to PST Converter create same Folder structure when converting into EML,MBOX,MSG,ICS and vCard Formats. EDB to PST converter do not change the internal folder structure of Mailbox PST file during the conversion of EDB to PST file. No changes done in the internal hierarchy of the Mailbox.
Get Free Demo From Here- http://www.vsoftware.org/edb-to-pst-converter.html
Convert the data from EDB file to PST file using the best InQuit EDB to PST Converter application that has lots of key features that makes the conversion of EDB to PST file formats. Through the help of this program, you can convert whole data into PST file formats.
The interesting features of this tool described here:
Multiple saving formats
: After the conversion process you have lots of saving formats to preserve the data for future use. The files formats are PST, EML, HTML, MSG, EMLX, vCal, MBOX, vCard.
Preview facility: Before finishing the conversion of EDB to PST you can see the preview of recovered mailbox along with emails, draft, task, deleted item, sent item, contact, calendar, notes, inbox, journals, and attachment.
Supporting version: it support MS Outlook version like 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019 and support OS windows version like 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1,10 (32bit & 64bit).
Split a large file into several files: Through the help of this program, you can split the large file into several small PST file as per your need without any hassle.
Read more: https://www.inquitsoftware.com
Fastly convert EDB data into PST with Enstella EDB to PST Converter Tool which facilitates fast EDB Conversion Procedure with all internal elements (contacts, calendars, task, trashed folders, embedded images, appointments and attachments) etc. This Tool provides many advantages for users like searching specific date of data with “Message filtering option”. It’s perfectly compatible with all windows and MS Exchange server versions.
Note- Get benefits of this EDB to PST Converter Tool in lowest price at $99.
If you are looking for the best EDB to PST converter, surely no one can give you the proper suggestions because many tools have different interfaces and features. It depends on the user's requirement. Few, days ago I used third-party tool EDB to PST converter from Bitdataconversion which provides me with the best results for converting multiple EDB files into PST format without any complicated method. It supports to export EDB mailboxes to PST Outlook, Live Exchange Server and Office 365 and other save selected email items into multiple email formats such as .eml, .msg, .html directly into disk directory. Download its free trial version and export the first 25 items per folder.
More details, visit:-
1176
The user can easy to migrate Pub1.edb and Priv1.edb file into PST without any hassle. eSoftTools EDB to PST Converter recover and convert exchange edb file to pst file without any problem and software convert entire data and emails to EDB mailbox items to PST and other many formats such as EML, EMLX, PST, MBOX, vCard, and HTML. It supports all OS of Windows 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1,10 (32bit & 64bit). You can download this software as a free demo version that allows you to convert 25 emails from each and every folder free of cost.
Software looks -
Read More - eSoftTools EDB to PST Converter Software - Pricing, Reviews, Alternatives and Competitor in 2019
