EML to PST Conversion
If you're looking for an EML to PST conversion solution, I recommend the eSoftTools EML converter suite, which will transform EML files to PST, EMLX, MSG, HTML, OST, and more. The EML file converter also provides a free trial version of the program for users to try out. Working on every version of the Windows operating system with ease. Fully compatible with all the EML-based email clients, i.e., Windows Live Mail, Apple Mail, Pocomail, etc. This software supports all MS Outlook versions.
Read more:- EML to PST Conversion
Is there a way to convert EML to PST without using Outlook?
There are several ways to convert EML files to PST files without using Outlook. To export EML files, you can use the manual method or the third-party Softaken EML to PST Converter tool. On the other hand, these techniques are difficult for inexperienced customers to learn. As a result, the best alternative for conversion is to employ a complex tool.
What is the best way to open EML files in MS Outlook?
You can drag and drop your EML files into the Outlook application to open them. Open the Outlook application and search for EML files on your computer. After that, drag and drop the necessary EML files into the Outlook application's folder. It migrates the files efficiently.
Tool EML to PST is the best and real clarification to smoothly convert all the Windows Live Mail EML data from EML files to Outlook PST file formats including –images, email, attachments, and other items. It supports all the versions of OS Windows and Outlook including – 2002, 2003, 2007, 2010, 2013, 2016 & 2019. You can directly switch single as well as numerous EML files into Outlook PST files at a time without losing any single emails. This converter offers a free demo Version that licenses the customer to safely move the first 10 email items per folder to Outlook PST.
DRS EML File Converter is another remarkable utility that helps users to convert EML file to various file formats including PST, OST, EML, EMLX, CSV, HTML, MSG, PDF, MHTML, PNG, etc. Furthermore, the software provides you a facility to migrate your entire EML files to Office 365, Gmail, Yahoo, IMAP, AOL, etc. email clients. It comes with easy user interface that allows non-technical users to operate the software with ease. To know more about the tool, you can download its demo version.
