Eraser 5.8.7 beta 3 wont erase USB networked
chris12923
I tryed everything I can think of but it wont erase files or folders from my Maxtor USB drive over the network any ideas? I also get no log popup which I have it set to popup for everything. Checking the log it says nothing to erase.
Thanks,
Chris
How are you erasing the drive? Over a network share? UNC path? Mapped network drive?
Also I think it may be helpful if you listed both your client and server OSes.
Thanks!
chris12923
Vista 64 is the remote and the host is Vista 32 bit. Using UNC path.
Thanks,
Chris
Overwriter
Hi Chris :D
Nice to see you posting on the forum !
You are doing some great bug hunting on the Eraser Trac ! :wink:
