Eraser 5.86a Sourceforge Release
Status
Not open for further replies.
Txv2
The hashes of the "Eraser 586a" from sourceforge and the same version posted earlier by Admin here: http://bbs.heidi.ie/viewtopic.php?t=322 ... 8040fdc2c4 do not match!
(taken Eraser 586a, erasersetup32.exe as an example)
MD5 Hash from the sourcefoge link : 0ae20406b2c03c0886b419f61911a857
Md5 Hash from the heidi.ie link : 50be8535e2478ac4f1037e17f94bc26c
If you want every new build you release to be taken seriously, than please post the hashes directly on the forum next to the download link. ;)
Overwriter
+1 :)
I have also been asking for this recently. It would be helpful.
wraithdu
Couple things with the new release -
1. The Gutmann Recycle Bin context menu entry (Erasext) is the wrong command. It is '-method Random 1' instead of '-method Gutmann'.
2. If I have 5.86 installed, do I have to uninstall it first before installing 5.86a? I noticed it uses a different installer, so I wasn't sure. I uninstalled 5.86 first just to be sure though.
Great work with everything by the way. Keep it up!!
Status
