Eraser 6.0.10.2620 issue
pburke1
I installed Eraser on an HP ZBOOK-17 running windows 7 pro 64bit and it will not work. after completing the install i receive an error saying the Default File Erasure method, Default unused space erasure method & randomness data source all have incorrect selections. So i tried to go into the settings see that nothing is selected for any of the options, so i then tried to change the selection by clicking on the drop down and no options appear, i tested and the .exe worked properly to install to a different machine so now i am out of luck and have no more ideas on what to try.
Do you have administrator access to this machine? Try installing by right-clicking on the install and select run as administrator.
