Eraser Does not Work, Help
Freelance
Install Eraser (6.0.7.1893),but it does not Work, the Hint Information As Follow:
The following settings held invalid Values:
Default File erasure method
Default unused space erasure method
Randomness data Source
These settings have now been set to naive defaults
Then I selected Ok, But Found No Option In Erase Settings Group, All CombBox were blank...what's more, It Can't Eexcute Any Erasure,even on a Single File...
Eraser Install Directory Tree As Follows:
文件夹 PATH 列表
卷序列号为 C8B4-1DAB
D:.
│ BevelLine.dll
│ DragDropLib.dll
│ Eraser Documentation.pdf
│ Eraser.exe
│ Eraser.Manager.dll
│ Eraser.Shell.dll
│ Eraser.Util.dll
│ Eraser.Util.FileSystem.dll
│ Eraser.Util.Unlocker.dll
│ ProblemTree.txt
├─en
│ Eraser.Manager.resources.dll
│ Eraser.resources.dll
├─nl
└─Plugins
│ Eraser.DefaultPlugins.dll
├─en
│ Eraser.DefaultPlugins.resources.dll
└─nl
Items In Registry As Follows:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Eraser]
[HKEY_CURRENT_USER\Software\Eraser\Eraser 6]
[HKEY_CURRENT_USER\Software\Eraser\Eraser 6\3460478d-ed1b-4ecc-96c9-2ca0e8500557]
"ClearCompletedTasks"=dword:00000001
"IntegrateWithShell"=dword:00000001
[HKEY_CURRENT_USER\Software\Eraser\Eraser 6\9977d7c4-c940-4b73-a02a-33c9ee2d47fe]
"ApprovedPlugins"=hex:00,01,00,00,00,ff,ff,ff,ff,01,00,00,00,00,00,00,00,04,01,\
00,00,00,e1,01,53,79,73,74,65,6d,2e,43,6f,6c,6c,65,63,74,69,6f,6e,73,2e,47,\
65,6e,65,72,69,63,2e,44,69,63,74,69,6f,6e,61,72,79,60,32,5b,5b,53,79,73,74,\
65,6d,2e,47,75,69,64,2c,20,6d,73,63,6f,72,6c,69,62,2c,20,56,65,72,73,69,6f,\
6e,3d,32,2e,30,2e,30,2e,30,2c,20,43,75,6c,74,75,72,65,3d,6e,65,75,74,72,61,\
6c,2c,20,50,75,62,6c,69,63,4b,65,79,54,6f,6b,65,6e,3d,62,37,37,61,35,63,35,\
36,31,39,33,34,65,30,38,39,5d,2c,5b,53,79,73,74,65,6d,2e,42,6f,6f,6c,65,61,\
6e,2c,20,6d,73,63,6f,72,6c,69,62,2c,20,56,65,72,73,69,6f,6e,3d,32,2e,30,2e,\
30,2e,30,2c,20,43,75,6c,74,75,72,65,3d,6e,65,75,74,72,61,6c,2c,20,50,75,62,\
6c,69,63,4b,65,79,54,6f,6b,65,6e,3d,62,37,37,61,35,63,35,36,31,39,33,34,65,\
30,38,39,5d,5d,03,00,00,00,07,56,65,72,73,69,6f,6e,08,43,6f,6d,70,61,72,65,\
72,08,48,61,73,68,53,69,7a,65,00,03,00,08,90,01,53,79,73,74,65,6d,2e,43,6f,\
6c,6c,65,63,74,69,6f,6e,73,2e,47,65,6e,65,72,69,63,2e,47,65,6e,65,72,69,63,\
45,71,75,61,6c,69,74,79,43,6f,6d,70,61,72,65,72,60,31,5b,5b,53,79,73,74,65,\
6d,2e,47,75,69,64,2c,20,6d,73,63,6f,72,6c,69,62,2c,20,56,65,72,73,69,6f,6e,\
3d,32,2e,30,2e,30,2e,30,2c,20,43,75,6c,74,75,72,65,3d,6e,65,75,74,72,61,6c,\
2c,20,50,75,62,6c,69,63,4b,65,79,54,6f,6b,65,6e,3d,62,37,37,61,35,63,35,36,\
31,39,33,34,65,30,38,39,5d,5d,08,00,00,00,00,09,02,00,00,00,00,00,00,00,04,\
02,00,00,00,90,01,53,79,73,74,65,6d,2e,43,6f,6c,6c,65,63,74,69,6f,6e,73,2e,\
47,65,6e,65,72,69,63,2e,47,65,6e,65,72,69,63,45,71,75,61,6c,69,74,79,43,6f,\
6d,70,61,72,65,72,60,31,5b,5b,53,79,73,74,65,6d,2e,47,75,69,64,2c,20,6d,73,\
63,6f,72,6c,69,62,2c,20,56,65,72,73,69,6f,6e,3d,32,2e,30,2e,30,2e,30,2c,20,\
43,75,6c,74,75,72,65,3d,6e,65,75,74,72,61,6c,2c,20,50,75,62,6c,69,63,4b,65,\
79,54,6f,6b,65,6e,3d,62,37,37,61,35,63,35,36,31,39,33,34,65,30,38,39,5d,5d,\
00,00,00,00,0b
"PlausibleDeniabilityFiles"=hex:00,01,00,00,00,ff,ff,ff,ff,01,00,00,00,00,00,\
00,00,04,01,00,00,00,7f,53,79,73,74,65,6d,2e,43,6f,6c,6c,65,63,74,69,6f,6e,\
73,2e,47,65,6e,65,72,69,63,2e,4c,69,73,74,60,31,5b,5b,53,79,73,74,65,6d,2e,\
53,74,72,69,6e,67,2c,20,6d,73,63,6f,72,6c,69,62,2c,20,56,65,72,73,69,6f,6e,\
31,39,33,34,65,30,38,39,5d,5d,03,00,00,00,06,5f,69,74,65,6d,73,05,5f,73,69,\
7a,65,08,5f,76,65,72,73,69,6f,6e,06,00,00,08,08,09,02,00,00,00,00,00,00,00,\
02,00,00,00,11,02,00,00,00,00,00,00,00,0b
"ForceUnlockLockedFiles"=dword:00000001
"ExecuteMissedTasksImmediately"=dword:00000001
"PlausibleDeniability"=dword:00000000
[HKEY_CURRENT_USER\Software\Eraser\Eraser 6\e2e55c15-f188-4293-a4b2-1d8a016103b5]
How Could I Solve the Problem?
Thank U very much!
Well, reading the FAQ will help :)
Use the link in my signature, and read the post on common Eraser problems. The answer is there.
