"eraser has stopped working" recreate
psy4216
as much as i saw this bug when i searched, i did not see the/a recreate method
i have found a way of consistently recreating the "eraser has stopped working" bug in 6.0.6.1376 under windows 7 ult 64 bit
under scheduler
select recurring
set as monthly change day to a few days in the future(i set 14th)
if done correctly it will display todays day(now being 12th) but next month (its displaying 12 may 2010)
edit** may need to edit the schedule by a day to recreate
i hope that makes sense:roll:
a work around is to go to your appdata folder
C:\Users\--USERNAME HERE--\AppData\Local\Eraser 6
delete the contents of this folder "task list" and restart the program
hope this is useful.
Please detail the reproduce steps in Trac as a bug. It will be highly unlikely that this bug will be fixed in 6.0.7 though (a test binary already has been signed and distributed for testing.)
That's a different problem.
To post a bug in Trac you need a user account. What I really need are steps to reproduce the error, i.e. what I need to do so that I can get Eraser to crash. Only that will allow me to fix the problem.
