Eraser on Vista RTM problem
kuusi
Have been using Eraser for past three weeks on Vista Business.
Only problem I have come across is that it does not erase the recycle bin contents.
If I right click on the recycle bin it always says the bin is empty regardless if it contains one or a thousand items.
Otherwise installs and seems to work without problem.
Technique
I have the exact same issue... Hopefully this can be resolved fairly easily by changing the command line in the context menu or by a minor version update...
Carver
I have used versions 5.7; 5.82 and I can erase recycle Bins in both versions. It might help if you tell us what version and what operating system.
Carver
Eraser 5.82 and Windows XP, I don't think that Eraser is fully compatable with Vista yet. I had hoped the Admin would answer that question.
