Erasure failed
donpaco
Hello,
I’ve Erase 6.0.10 On my Desk PC , I’ve one of the HD that I used as OS disk thatnow I use as Data disk only. I’ve used Erase to have more available free space on disk but I’m not able to erase the folder "Windows" and the folder "Recycle" inside my HD. These folders are not erasable. What I’ve to do? What I’m mistaking. Thanks a lot for your answer.
garrett01
Administrator
Staff member
if the disk is attached to your windows OS you might have permissions issues. The quick solution is to format the drive, then do a freespace erase and finally format it again. The last format is just to tidy up the file table.
