Exchange EDB to PST Converter Best Software
Sometimes, the conversion of Exchange EDB to PST file becomes important for uses. For this task EDB to PST Converter application is one of the best. Before the actual conversion, it shows you the preview of recovered mailbox then easily export data into PST, EML, EMLX, MSG, MBOX, vCal and vCard file format according to users requirement. It supports OS Windows’s version Win 95, Win NT, Win 98, Win ME, Win XP, Win Vista, Win 7, Win 8, and Win 8.1, Win 10 (32bit & 64bit). It is the preview of all database of EDB files before restoration from EDB to Outlook PST. In its demo version, you can convert 30 emails per folder without any cost that is absolutely free of cost.
Read More: InQuit EDB to PST Converter
Enstella Systems give you best solutions for converting EDB data to PST formats. It is completely able to convert the private and public .edb files with all Emails properties (to cc, bcc, date, time and Subject). And there is no file size limitation to performing EDB Conversion procedure. EDB to PST Software provide demo version for users at free of cost. This software smoothly works with all Windows and MS Exchange server versions (5.0, 2000, 2003, 2007, 2010, 2013 and2016).
Note- Get benefits of this EDB to PST Converter Software in lowest price at $99.
Shoviv Software is a very popular name in the field of EDB to PST Converter which provides good EDB to PST Conversion and it’s embedded with advanced functions like Message filtering, email address convention, and PST files splitting. Exchange users can easily convert all the mailboxes of EDB files to PST formats with all internal entities like Contacts, task, calendars, appointments, attachment, etc. With this software, users can extract .edb files into different formats like PST, EML, MSG, and HTML. the software is supported by all the Windows OS and MS Windows Server and the software is compatible with all the MS Outlook Version and MS Exchange Version (2000, 2003, 2007, 2010, 2013 and 2016). Shoviv EDB to PST converter provides the free trial version which helps you can migrate first 25 items per folder.
1117
