Exchange Server Recovery with EDB to PST Converter
MS Exchange EDB to PST Recovery Software give the secure and complete solution for users to recover EDB file and Convert Exchange EDB mailboxes to PST file format. It is a professional tool to convert EDB files into Outlook PST without dismounting the database.
Through the help of this application you can also convert more than one file.
Before the conversion process it deeply scan the EDB file and detect the entire errors then remove them. It gives 100% accurate result. The tool always gives you opportunity to export priv 1edb and pub 1 edb file which is the best features of this.
Before the conversion it show preview of recovered mailbox then export the data into PST, EML, EMLX, vCard, MSG, vCal and MBOX file formats. It also support cloud-based application Office365 & Live Exchange Server. This application is compatible with all the version of MS Outlook up to 2019.
If you want to evaluate the working performance of this tool then you can try its free demo version to convert 30 emails per folder free of cost without any problem.
Read more: InQuit Exchange Recovery Software
Whenever you need to do the conversion of EDB damaged file into PST file or any other format best tool to do so SysOZ EDB to PST converter is best option to do so it has so many features that make your work very easily and quickly. Here I would like to tell you some of the features of this tool in short:
• This tool supports the conversion of EDB file into MBOX for Thunderbird and Apple Mail.
• Also supports EML, MSG etc. (for contacts), vCal (for calendar) HTML, Office 365, Outlook PST and Live Exchange Server.
• This software can also convert the password-protected, corrupted and highly encrypted files that to very easily.
• This software can repair and can convert Office EDB files in Office 365 and Live Exchange Server.
• You can avail a free demo version of this software, as well as you will get 24x7 customer support services.
Read more: SysOZ EDB to PST Converter
