Export and Convert NSF files to PST
The eSoftTools NSF to PST Converter Software that swiftly export and convert NSF files to PST along with all the mailbox components such as emails, tasks, drafts, journals, calendars, and contacts. It converts NSF files in bulk by applying batch process and also migrates Lotus Notes NSF files to numerous file formats PST, EML, EMLx, MSG, HTML, MHTML, MBOX, VCF, CSV, and ICS. Preserves original folder structure and all the email attachments such as to, bcc, cc, from and date. The tool allows you to convert all MS Outlook editions upto 2016. Try its free demo version that allows you to migrate 50 items per folder without any assistance.
Get more info: Convert NSF files to PST
If you want to convert Lotus Notes to Outlook then, Users can use Shoviv NSF to PST Converter Tool. It easily converts all the Lotus Notes NSF data such as- emails, contacts, tasks, calendars, notes, etc. to Outlook PST format.
It provides the many advanced functionalities like-
1- Bulk conversion from Lotus Notes to Outlook.
2- Previewing of Source data option is in the tool
3- Split PST option, convert large size Notes file to multiple small PST files.
4- Date filter, export NSF data of a specific time range.
5- 100% accurate data conversion.
6- No file size limitation.
7- Maintains data integrity and accuracy after the migration.
8- Compatible with all versions of Windows OS and IBM Notes, Outlook, Domino Server.
More details, visit:- Lotus Notes archive to Outlook
I had recently found a Lotus Notes NSF to PST Conversion Guide for transferring the data instantly from NSF file forma tto PST format for accessing the data in Outlook email client. You can apply this technique on any version of Windows system suitably and make you data file easily migrated.
The eSoftTools NSF to PST Converter Software is the highly suggested among all of the third party tools. This tool permits to export NSF files to Outlook including all the mailbox items like emails, tasks, drafts, journals, etc. Users can download it and use it's free demo version.
Read more:
You can use the NSF to PST Converter Tool by data-recovery-solutions.
Goto: NSF to PST Converter tool to convert/Export Lotus Notes to Outlook PST
The software allows you to convert single as well as multiple Lotus Notes file into Outlook PST file. The software also helps users to Export Lotus Notes to Outlook along with the entire emails, contacts, calendars, attachments, etc. in user mailbox without losing its originality.
