Export Exchange 2007 mailbox to PST
alex786
Users have multiple factors due to which they think to export Exchange mailbox to PST file format. Generally, users demand a professional tool that can do this task effortlessly without taking too much time. Users must look at the Shoviv Exchange Recovery Manager to complete this task in a minimal time. There is no requirement for the technical expertise to handle this software for processing the Exchange 2007 mailboxes into Outlook PST.
This software has no restrictions on adding large-sized PST mailboxes and processing them into PST in a single go. The folder hierarchy and integrity of the data will not change even after completing this exporting procedure. Moreover, users can convert Exchange mailboxes into other file formats, including MSG, HTML, RTF, vCard, etc. Users can preview the added mailboxes in this tool to ensure of selecting the correct one.
This software is also helpful in repairing corrupt PST files and recovers the entire data from a PST file easily. It is easy for users to export Exchange 2007 mailbox to PST file format as it has a simple user interface. This tool allows splitting the resultant PST file; here, users can set the size for the resultant PST file according to their choice.
Read More: www.shoviv.com/blog/export-exchange-2007-mailbox-to-pst/
