Factory Reset iPhone without Passcode
Daisy514
When we do factory reset with our iPhone, we may lost all our iPhone data, so we’d better not to do it. But sometimes, we have to factory reset our iPhone to solve some iPhone bugs, like iPhone stucked in locked screen, or when we forget our passcode. Now it’s time for us to solve this problem, follow below steps and learn some methods.
Factory Reset iPhone with Home and Power Button
When there is no passcode, we can factory our iPhone with home button and power button, please have a check.
Now press your power button and home button together and hold on until your iPhone close and begin to restart.
When you see Apple logo shows up on your screen, release the buttons.
Factory Reset iPhone with iTunes
When there is no passcode, we can also factory reset our iPhone with iTunes, before doing it, please make sure your iTunes is with latest version. see below steps.
Now connect your iPhone matched USB cable with PC, and please Don’t connect the other side with our iPhone.
Then turn off your iPhone, press your home button and hold on, and at the same time connect another side of USB cable with your iPhone.
Wait a few seconds until iTunes icon appear on your screen, then release home button, now we’re in recovery mode.
Launching iTunes on your PC manually when it doesn’t do it automatically. And click “Restore” when it pop up options with “Restore” and “Update”.
Now wait until iTunes connects to iPhone software update server, and on iTunes confirmation box, click “Restore and Update”. and continue it with “Next” and “Agree” according to its instruction.
When a copy of iOS compatible for your iPhone is downloaded, iTunes will use it to restore iPhone to factory reset.
Backup iPhone Data before Factory Reset
As we know when we do factory reset, we’ll lose some iPhone data, so when there is something important, we’d better do some backup before doing factory reset.
Here, we’ll introduce you a third-party software iRefone, which can not only help us backup iPhone data selectively, but also can help us recover more than 16 kinds of files, including contacts, notes, messages, photos, reminders, calendars, call history, voice memo, WeChat messages ect. It allows us to preview them before restoring, and it can be compatible with iPhone, iPad and iPod.
When you need, you can download and install the free trial version from its website to have a try.
Step 1. Run iRefone, connect your iPhone with PC. Choose “Recover from iOS Device”, and click “Start”.
Step 2. Then we’ll enter the new interface with many data icon and media icon that iRefone can recover, find and click “Message” icon for example, and it will be scanned by the software.
Step 3. After scanning, you can preview and choose messages you need to backup, tap on “Recover to PC”, and choose folder path to save them.
For more similar issue, you can check below article for reference:
Extract WeChat Chat History from iCloud Backup
If you want factory reset iPhone from Settings > General > Reset > Erase All Contents and Settings, we always need enter passcode to confirm the factory reset of your iPhone, but how to reset iPhone without password? You until have several ways to factory reset iPhone, by iTunes, by iCloud, by Eelphone iPhone Unlock, you can factory reset iPhone for free and you also have the quickest way to factory reset your iPhone.
If you want to factory reset your iPhone, you need to do it by making some changes in settings. But. after that you need to confirm that by entering the passcode. If you don't have a passcode or forgot the passcode, it is a bit difficult. You need to use iPhone unlocker software.
