Feature Request :D
Mameluke
Hi there guys and gals this is my first post
is it possible to add size or at least the windows assigned drive letter to the menu where you choose what partition needs to be deleted?
I need to wipe one partition usually and the display does not help at all when it comes to differentiating the listed partitons (well it displays some numbers but those don't help much)
Thanks a lot :)
Am I the only one who has this problem?
Mame
Disk size (and other attributes) will eventually be available through the GUI.
Reporting drive letters from Microsoft Windows is not planned because doing this safely requires reading the registry.
Consider this alternative:
1. Put an empty NTFS filesystem in the partition that you wish to wipe.
2. Run a free space wipe with Heidi Eraser from the host operating system.
3. Remove the NTFS filesystem.
This does not work on the system partition, but the system partition is usually first on media.
No.
