Hard drive size limit
AlReiter
Is there a limit to the size of hard drive that DBAN can clean? I am trying to clean 160 GB Raid 1 drives on a Dell Dimension 8400 PC (3.4 GHz P4 processor). After almost 3 hours of running I received an error (unforunately I didn't write the error down). I rebooted and it's been running now for almost an hour and has reached 15%, round 1 of 1, pass 1 of 3.
Thanks.
AlReiter
It just failed again after about 90 minutes
The data on the screen reads:
CPU: 0
EIP: 0010:[<c012a3db>] Not tainted
eax: f7cfe274 ebx: 00000001 ecx: c03d3000 edx: 00001fe9
ds: 0018 es: 0018 ss: 0018
Process swapper (pid: 0, stackpage=c032d000
Stack: co1ab11a cee70de0 00000001 f7cfe274 f7cf8c00 00000a00 00000001 c03d3000
c01ab401 f7cf8c00 00000001 00000009 00000001 00000001 c032df34 00000050
00000000 f7cf8cb8 f7cfe274 00000080 00000000 00000001 00000080 00000080
Call Trace [<c01ab11a>] [<c01ab401>] [<c026cbbe>] [<c01a615e>] [<c01a6039>]
[<c0114d4d>] [<c0114c98>] [<c0114aee>] [<c0109494>] [<c01069e6>] [<c0105000>]
[<c010b4a0>] [<c01069e6>] [<c0105000>] [<c0106a09>] [<c0106a61>]
Code: 0f ba 6b 18 00 eb 04 0f b3 43 18 89 d8 e8 3f ff ff ff ff 4b
<0>Kernel panic: Aiee, killing interrupt handler!
In interrupt handler - not syncing
Hope I entered all of that correctly.
Tanks
Thanks for the verbose information. It helps.
This is usually caused by bad memory. Run the diagnostic from http://www.memtest.org/ on this computer.
The wipe may finish if you disable verification by pushing "v" at the blue interactive screen. Wipe this disk in another computer if possible.
AlReiter
Darik,
Want to make sure I understand your instruction on entering the "v". Is this after I've entered autonuke?
Thanks.
Al
