How can I go backward step?
dolphin
I want to go main menu when it was in dban mode sometimes.
but I don't know.
so..I used to off/on the system.
how can I go backward?
If it is possible to modify the program,
what sources are modified?
The program cannot return to the "boot:" prompt.
If it is possible to modify the program, what sources are modified?
You can rerun dwipe, or any other program, by customizing the rc script.
