mithileshtata
To mass delete duplicate emails in Outlook, you can follow these steps:
- Sort Emails by Subject: Sort your emails by subject to group duplicates together. You can do this by clicking on the "Subject" column header in your inbox or any folder where you suspect duplicates might be.
- Identify Duplicates: Look for emails with the same subject line. These are likely duplicates. You might also have duplicates with slightly different subject lines, so keep an eye out for those as well.
- Use the Aryson Outlook Duplicate Remover Tool that deletes or removes mass duplicate emails from Outlook in the simplest ways.
- Use Outlook's Built-in Tools:
- Clean Up Tool: Outlook has a "Clean Up" tool that can help you remove redundant messages in a conversation. This can be found under the "Home" tab in the "Clean Up" group. It's useful for removing redundant emails within a thread.
- Find Duplicates Tool: Outlook also has a built-in feature to find and remove duplicate emails. This feature might be located in different places depending on your version of Outlook. In newer versions, you can usually find it under the "Home" tab in the "Clean Up" group, labeled as "Clean Up Folder" or "Delete Duplicates".
- Manually Delete Duplicates: If Outlook's built-in tools don't catch all duplicates or if you prefer a more manual approach, you can delete duplicates manually:
- Select the duplicate emails while holding down the "Ctrl" key (or "Command" key on Mac) to select multiple emails.
- Once selected, press the "Delete" key on your keyboard or right-click and select "Delete" from the context menu.
- Empty Deleted Items Folder: After deleting the duplicate emails, don't forget to empty your "Deleted Items" folder to permanently remove them from Outlook.
- Consider Using Third-Party Tools: If you have a large number of duplicates or if Outlook's built-in tools are not sufficient, you might consider using third-party duplicate removal tools specifically designed for Outlook. These tools can automate the process and provide more advanced features.
