How do I read the log and did i do everything correct?
baly
Hi,
I ran DBAN on 2 HDs in my other PC now and it was finished really quickly. in less than 2 hours, in quick-mode, and they are two 120 GBs.
Now it sais:
DBAN finished with non-fatal errors. check the log for more information.
Hardware clock operation start Date: ....... 16:22 .....
" " " finish date: ...... 18:02 ....
My questions:
Was everything wipes correctly?
How can I read the log? (i did from cd)
Thanks already!
Rgds,
baly
You must insert a floppy disk to get the log file if you are running DBAN from CD-R.
A log file viewer will eventually be added to DBAN.
No. Wipe each disk separately. One or both likely have bad sectors.
