How do I uninstall Eraser?
pgarden
There is not a file associated to uninstall Eraser program so how do I uninstall Eraser? It is not listed in the Add/Remove or CCleaner list so how do I uninstall the Eraser program?
Which version of Eraser did you download? If you downloaded the portable version then just delete the programs, no uninstall is needed.
