how long on a 200gb hdd??
zappyisfun
i have a 200gb sata-2 hdd that i am selling and i want to make sure EVERYTHING is off and unrecoverable.
what pass should i do and how long should it take?
computer specs.
amd anthlon 3700+ at 2.2ghz
2gb pc3200
abit av8 motherboard with via chipset.
Robbie
computer specs.
2gb pc3200
if you run the default (which I think is a 3 pass DoD) it should take about 8 to 10 hours for a 200GB drive. Probably closer to the former.
Overwriter
computer specs.
2gb pc3200
If I were you I would run a single random pass completely to secure your old data and then run whatever you want for as long as you want afterwards for paranoia.
florila
Can you start the computer with just a motherboard? I am buying my computer components one at a time. And I just received my motherboard. I already have a power supply. What is going to happen when I try to start up my computer? Also, how can I tell if my motherboard is dead or working. Any indications? Thank you, 10 points for best answer.
_______________________
external keyword tool ~ keyworddiscovery.com ~ keycompete.com ~ compete.com ~ webmasterworld.com
Valkyrie
Heya Zappy, i find the autonuke (shortdod) takes a little under 6 hrs on a 500gb hdd. Using this as a baseline, think it's probable your 200gb drive will take about 3/4 hrs.
Heya Florila and yikes, you're scaring me bud. =)
It's great to build your own pc, think you could do with a bit of advice tho. For heavens sake, please don't try running what can't even be called a system with just a motherboard and psu. These are good sites for building info............................................
http://www.buildyourown.org.uk/ Very good forums for specific questions on buildyourown.org
http://www.buildeasypc.com/index.htm
