How to Backup Office 365 Mailbox to PST Format
If you need to backup your Office 365 mailbox to PST format then you need to use Office 365 Backup and restore tool to backup office 365 mailboxes as PST and EML file format and import/restore PST to Office 365 account. It's a complete solution which offers bundle of features to export Office 365 mailboxes to PST format.
fradiannevin
Office 365 Backup & Restore, a wonderful third party software, capable to backup single or multiple Office 365 mailboxes at a time into Outlook PST file. The software supports all editions of Office 365. To get more information about the software and to download its free evaluation version, visit- https://www.nucleustechnologies.com/office-365-backup/
sandyy
Office 365 Backup Tool is another solution that I would like to recommend you to use for archiving Exchange Online/Office 365 mailboxes to PST file. It is one of the finest Office 365 email backup solutions that helps users to backup their Office 365 mailboxes to PST, EML, PDF, EMLX, MBOX and MSG.
I think you should try the best Office 365 Backup Tool that supports you to completely extract backup of Office 365 to PST, MSG, MBOX, EML and EMLX format without any problem. You can simply activate this application on all Windows versions such as 7, 8, 8.1, XP, 10 and so on. This tool is easily accessible with the basic knowledge of computer. Free demo version facility is available for user evaluation that allows saving first 10 items without any cost.
I would like to recommend Office 365 Backup tool for Mac to export Office 365 data to PST, MBOX, EML file format and many more. Free trial version of the software is also available for users by which they can test the tool's efficiency in its trial run. Users can take mailbox backup smoothly with Admin account credentials. This Utility has extra ability to restore pst data to Office 365 by selective date range and supports latest versions of Mac Operating System too.
devin
Try office-365 backup tool for reliable and accurate backup along with multiple benefits that will help you to customize your conversion as per your demands. it works with Windows XP , Vista ,7,8,8.1, and 10 that export data accessed to any version of outlook and other client and that tool create a backup in one individual account at a time and they require password and username and that software work in internet connection and there is an available trial version of this software. For download this software or more detail visit: Office 365 Backup - How to Get Easy and Fast Backup of Entire Office 365 Files
alex786
To export Office 365 mailbox to PST, EML, Live Exchange server or Live Exchanges server to Office 365 and PST, you can use Shoviv Exchange Recovery manager software. It has a free trial version and a good technical support team as well.
Read more: www.bitdataconversion.com/exchange-server-recovery.html
davies
Do you need a solution to export Office 365 mailbox to PST format? If yes, you can try Office 365 Backup solution to restore and export Office 365 mailboxes to PST and EML format. There is no size limitation imposed on PST files while importing PST in Office 365 account. It provides impersonation option for admin to transfer multiple user accounts. Apart from multiple conversion benefit, software provides a flexible option to restore PST to Office 365 by choosing selective date filter option. I found a blog. You read that blog from this link: Tricks to Save Office 365 Emails – Office 365 Emails Locally
You can also use the Office 365 Backup and Restore Tool for MAC
With this tool you can easily keep the backup of the Office 365 Mailbox to your MAC System. Also with this utility you can easily saves the backup of mailboxes in PST, EML, MBOX, PDF, MHTML, and MSG. Users acn also migrate Office 365 mailbox to Gmail, Yahoo, Zimbra, Thunderbird, and IMAP with great ease. This utility is fully compatible with all the versions of MAC os.
