How to convert Zoho Mail to PST?
Eva Suzan Adom
I am using Zoho Mail application to transfer data. But now I decided to transfer my emails from Zoho to Outlook PST for the safety access. Is there any good method to perform this migration process?
Marliza
To convert Zoho mail to PST, you can use the help from following mentioned article link. It provides one easy manual solution to export Zoho to PST. Refer the link for more information.
Visit: http://technews2day.com/how-to-import-zoho-mail-to-outlook/
If you are not able to use this manual procedure then you can use another one expert technique called SysTools Zoho Backup Tool, which can perform the migration process without any hurdle, it also mentioned in this write-up.
Thanks & Regards
