Know how to Export Zimbra TGZ to PST? Use KDETools for Zimbra Converter is a most trustable program that 100% provide you multiple conversion option to convert multiple user accounts from Zimbra TGZ files to different file formats – Outlook PST, Office 365, MBOX, Gmail, EML, MSG, PDF and NSF. During the conversion, the Zimbra TGZ to PST Converter software is best to use utility to perform migration of multiple users accounts from Zimbra TGZ files to PST for Outlook 2019, 2016,, 2013, 2010, 2007 etc
http://www.zimbra-converter.com
How to Export Zimbra TGZ files to Outlook?
  • Download and Run the KDETools Zimbra Converter software on your Windows system.
  • Go to the Browse button and add single or multiple accounts from Zimbra TGZ files to whom you want to migrate.
  • Load Zimbra Mails and View TGZ files all items, folders. ...
  • Click on Export button to Select PST file format to export. ...
  • Click on Specify output SAVE destination. ...
  • Click on Convert button to Start the conversion.
hopemarha
If the user is looking for a better solution for Zimbra TGZ email all files easily convert into Outlook PST format, then the user can use this Zimbra to PST Converter software. With the help of this tool, the user can solve their all conversion-related problem. This application provides a free demo version for user help.
See more info about this software:- Zimbra TGZ 2 Outlook PST
hopemarha
If you are seeing a better solution for Zimbra to PST conversion, then you can try of TGZ Migrator. The software converts all data of Zimbra TGZ files emails, attachment and zipped file data into Microsoft Outlook PST format. TGZ to PST Converter software remove delete all duplicate TGZ file data during the migration. This application provides a free demo version and converts 10 files as a trial.
Get more info here:- Software to Convert Zimbra to PST
camilia
If you want to export Zimbra TGZ to PST then you can try TGZ to PST Converter. This software is safe and secure for the conversion of Zimbra TGZ to PST. Some features are:
  • The software can export TGZ to multiple file formats such as PST, MSG, EMLX, MBOX, PDF, HTML, NSF and etc.
  • This software is capable to export oversized TGZ files to PST format.
  • The Meta properties are preserves including Attachments, Cc, Bcc, Date, To, Time, Subjects, etc. and all folders of TGZ files are export without any error.
  • Securely export TGZ to cloud-based applications like Office 365 and Exchange server without any problem.
Read More: https://zimbra.org/extend/items/view/free-method-to-export-zimbra-tgz-to-pst
tomhayden
TGZ to PST Conversion Tool will never resemble a worrying task any lengthier. With TGZ to PST Converter as the migration software, you will have the bulk to change over the files with correctness.
