How to fully erase temp inet files?
programm
Located in
C:\Users\%username%\AppData\Local\Microsoft\Windows\INetCache
files are stored there and cannot be moved out, cut doesn't work. So instead of sending them to the recoverable free space with deleting cookies and history, how to fully erase them? Adding the folder and running task does nothing.. files r still there, only says it cannot delete files in Content.IE5 but that folder is not the point, the files are in InetCache\ not subfolders.
Can Eraser do that or not?
